Some questions about macro programing
AtomicNico
Nuclear
May 10, 2016
62
Hello everybody,
As you can see I'm new to this forum and I browsed it searching for my answers and unfortunately I didn't find it, so here I am!
-Can you change of workbench while you're executing a macro through the "CATIA.StartWorkbench ("name of workbench")?
Like I want to extract some datas in analysis workbench then change of workbench to extract mass, all of that in 1 macro
- What is the differences between Product and ArrangementProduct when you declare something? And sometimes I can see
objArrRun As Run​
objArrRuns As Run[highlight #EF2929]s[/highlight]​
Is there a difference? Putting an S won't make a difference?
- For the function .Search, I saw some ways to write it and I wanted to the differences and the conditions of writing one or the other:
oSel.Search "'Assembly Design'.Part, all"​
or
oSel.Search "(CATLndSearch.Part),all"​
Does the CAT***Search is depending on the workbench you're currently working in?
- I saw several topics about finding the mass and the inertia through a macro which used the 2 sames ways as I saw on other sites, but when I tried it on my computer, none of them worked, so, in which cases do you use these 2 ways:
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench(“SPAWorkbench“)
Dim productInertia As Inertia
Set productInertia = TheSPAWorkbench.Inertia.Add(Product)​
and
prdProduct As Part
On Error Resume Next
Set productInertia = prdProduct.GetTechnologicalObject(“Inertia”)​
FYI, I'm working on a computer where the documentation of CATIA was erased
Sorry if bad english, not my first language.
Best regards
No, it's a product I'm passing
Set oManager = objProductMat.Item(k).GetItem("CATMatManagerVBExt")
oManager.GetMaterialOnProduct objProductMat,Mat
And it doesn't change if I put
Dim objProductMat As Part
or
Dim objProductMat As Product
and the material is apply to what?
Eric N.
ok i did test your code and I have the same problem
Code:
does not find material on the product if the product is a part instance... you' ll have to work with the part
so use:
Code:
oManager.GetMaterialOnPart objProductMat.ReferenceProduct.Parent.Part,Mat
Be aware that this line will fail if objProductMat is not an instance
Eric N.
Ok, thanks Eric, I will try it Tuesday when I come back to the office but what is an instance exactly?
this is 3dx 2016X but V5 logic is the same:
Eric N.
Ok I'm back to work and I tried the modification, I still can't get the material even though I think i have the same configuration as you (with what I think is an instance)
download.aspx
where is the error message / line?
Eric N.
REMOVE ALL ON ERROR RESUME NEXT !
ALL OF THEM
Eric N.
The error is still on the GetItem method then
Ps: I'm sorry, I'm extracting other things and at each try I'm adding something, and I put the On Error back to try the other informations
use VBA debug tool (Locals) to make sure variable are Dimed properly use V5Automation.chm as reference in chapter : Applying or Retrieving a Material on a Product, a Part, or a Body
Eric N.
