MattEdwards
- Mar 19, 2024
- 12
I have a 2D (die cut) part, where I'd like to dimension the distance between a hole and a curved edge. The measurement needs to be taken parallel to the long straight edges of the part; if it's measured at an angle the nominal would change. Is the measurement orientation implied already? How do I explicitly specify the orientation of the measurement?
