standard callout for "stock size" in drawings 3
pavvpk
11
Hi
What is correct way of specifying stock size for machining print. For example if holes need to be drilled on a 1/4" thick plate.
- Reference the dimension in parenthesis "()"
For example - (.25)/(.250) - depending on level of tolerance looking for stock.
OR
- calling out "STOCK" after the dimension?
For example - .25 STOCK / .250 STOCK
thank you very much,
pavvpk
I just came across a part we're being contracted to manufacture and in their notes, it states:
"MAXIMUM PLATE MAXIMUM AS ROLLED PLATE THICKNESS SHALL NOT EXCEED 3.00
THICKNESS INCHES."
A quick glance through the drawing seems to indicate the part will not exceed 2.25 at it's thickest.
That leaves things open but yet... controlled. I thought that may be a solution for some circumstances this topic addresses.
_________________________________________
NX8.0, Solidworks 2014, AutoCAD, Enovia V5
