ahmedhegazi
- Jul 5, 2007
- 92
Hi all
i have a column supported on pile cap for 2 piles
when i checked ACI02 15.15.3 i found that i can use strut and tie model for this pilecap, when i followed the procdures for calculating the nodal dimensions i found that i am having dimensions for Hz chode for column node more than column dimension which can not be!
so what can be the main problem?, i think that i am having high forces on this pile cap.
is there any other ST model i can assume?
Note: i assumed normal V shape path for ST and the angle was angle to 41 between the chords
