I am involved in a project to design pressure equipment handling either Nitrogen, Hydrogen, Oxygen or a mixture of these - all at very low temperatures. These will all be gaseous within the equipment. Design temperature is -257C/-430F, design pressure is 20 barg.
Could someone please suggest an appropriate material of construction, bearing in mind the equipment has to be designed to a recognised design code such as ASME B31.3 or ASME VIII or similar.
Thanks in advance.
Thanks in advance.
