MediumRare
Computer
Hi
I suspend large metal objects ready for spray painting from a beam using chains, S-hooks and U bolts. The #1 problem is that the painter has to move around the object during spraying, instead of being able to rotate the object around on one axis. Problem #2: the joint must be able to take heavy loads (100 kg +) and problem #3 the joint must tolerate foreign material such as metal dust, overspray and shock. Any tips about designing and making a simple swivel joint - apart from going to buy one?
Much Appreciated.
Much Appreciated.
