1
- #1
GregLocock
Automotive
- Apr 10, 2001
- 23,757
Never seen the attraction myself, but this paper investigates why a bungee jumper accelerates at more than 1g
Good stuff.
Good stuff.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Another factor.Bungie cords stretch under their own weight.
Sure,Would that add to the acceleration?
When the chain is fully down there is no kinetic energy in the system (except for some pendulum oscillations): this means that all the initial potential energy, temporarily transformed into kinetic, is completely consumed by internal friction in the chain.
The chain will bounce up and down and burn up energy with air resistance and friction. A bit of a different situation.The energy argument is used incorrectly IMO.
Take an inextensible chain suspended at one end, as in the bungee, falling under its own weight. When the chain is fully down there is no kinetic energy in the system (except for some pendulum oscillations): this means that all the initial potential energy, temporarily transformed into kinetic, is completely consumed by internal friction in the chain.
This should mean that the cord does not add any actual energy to the mass of the jumper, so the acceleration can't be higher than g (which is BTW evident per se).
I would like to analyze this scenario with Lagrangian mechanics, but of course g is the maximum acceleration for a freely falling mass on earth's surface.
Like, "Push with a rope"?If you want the jumper to experience an acceleration greather than g, then you need to exert a force on the jumper,
