thermal buffering testing
hsemus
Petroleum
Apr 26, 2012
42
Hi
what is thermal buffering in forging material HT process.,
is there any standard for using thermal buffering for low carbon high strength alloy materials .
thanks ..
whats the key benefit for doing this, compare to the current QTC testing
Since material receives a better quench (higher cooling rate, better properties) near the surfaces of a part, a thermal buffer allows testing of material that more closely represents through-thickness properties of a forging. API 6A, for example, requires mechanical properties 1/4T (1/4 x thickness) from the exterior surface. The material between the specimen and the exterior of the part would be the "buffer".
