thread560-238442 I have used the 1
vjxzy
Automotive
Jan 31, 2019
13
thread560-238442
I have used the code in the above thread but the part number showing in the txt file is only 20 space. Is there any other additional code to get full name of the part
I am not sure if you can modify your code to show more characters. In "AssemblyConvertor" class I do not see any options on how to set that.
But, you can try something like below:
Code:
Option Explicit
Sub Main()
    Dim CATIA
    Dim doc, prod
    Set CATIA = GetObject(, "CATIA.Application")
    Set doc = CATIA.ActiveDocument
    Set prod = CATIA.ActiveDocument.Product
    Dim dict
    Set dict = GetProductBOM(doc, prod)
    Dim k As Variant
    For Each k In dict.Keys
        Debug.Print k, dict(k)
    Next
End Sub
Function GetProductBOM(doc, prod)
    Dim dict
    Dim curr As Product
    Dim dictKey As String
    Set dict = CreateObject("Scripting.Dictionary")
    For Each curr In prod.Products
        Do
            dictKey = curr.PartNumber
            If dict.Exists(dictKey) Then
                dict(dictKey) = dict(dictKey) + 1
            Else
                dict.Add dictKey, 1
            End If
        Loop While False
    Next
    Set GetProductBOM = dict
End Function
It prints into a debug window a BOM: Part Number, Quantity for the first level of the active product. If you would like to include also deeper levels, you have to use recursion.
Tesak
- Text along a curve for Catia V5
Thank you for your reply i'm not getting it exactly ill turn to figure it out.
