Feb 25, 2020 #1 GAL02 Mechanical Sep 2, 2015 55 0 0 KW Hi! How do we calculate Torque to be apply on bolts? If Bolt size, length & Nut size known to us. bolt size: 2 1/2" Length : 17" Pl. Revert With regards
Feb 25, 2020 #2 3DDave Aerospace May 23, 2013 10,569 2 38 US Read up at http://www.boltscience.com starting with https://www.boltscience.com/pages/basics1.htm Upvote 0 Downvote
Feb 25, 2020 #3 XL83NL Mechanical Mar 3, 2011 3,043 0 36 NL Depends on the application. Is this structural, or for a piece of pressure equipment? For the latter see ASME PCC-1 Huub Upvote 0 Downvote
Feb 25, 2020 #4 r6155 Mechanical Jan 12, 2010 2,677 0 36 AR Always think in bolt elongation (irrespective of diameter, with or without hydraulic tensioner), not in torque. Regards Upvote 0 Downvote
Feb 26, 2020 Thread starter #5 GAL02 Mechanical Sep 2, 2015 55 0 0 KW Hi! Thanks all! of you i will get it done with your guidance. With regards Upvote 0 Downvote
