Brian Malone
Industrial
- Jun 15, 2018
- 416
Tony Nissen left Ocean Gate in 2019, some time after David Lochridge was fired in 2018.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
blakmax said:I really hope that they didn't use "injection repairs"....The difference in strength is dead set zero.....I am astounded that almost every composite manufacture still uses this technique.
Tug said:which indicates that there is no difference between repaired and unrepaired.
Swinny said:He's saying that once the resin is cured - including the inside surface of a void which existed during curing - it is not very chemically active and is very difficult to bond to without significant prep, which you can't do to the inside of a void.
TugboatEng said:Swinny, I read that the compressive strength of carbon fiber is quite low, maybe 10% of a UTS of 175ksi.
SWComposite said:please provide specific references
blakmax said:I will be very interested to see other reliable test results. Show me!
