tmaly1
- Oct 13, 2003
- 31
Folks,
I'm hoping you share your opinion with me on this.
Do you consider the Minimum Utility Fault Current on the transformer primary side when setting the instantaneous element for the protective relay (115 KV side) or you need to be concerned only with the Maximum Fault Current??
Should the instantaneous setting pickup be below the maximum and above the minimum or as long as it is below the maximum, that's good enough?
Thanks for your feedback in advance.
