Well not really knowing what cycle to use, just for the heck of it, I ran a quick thermodynamic simulation for two cases just for the standard Otto cycle. I just used “ideal” (non-realistic) valve timing.
For the first case, I used rc = 9.5, a burn duration of 50 degrees, spark at MBTT, and an equiv ratio = 1.
Then for the second case, I used rc = 20, a burn duration of 20 degrees, spark at MBTT, but backed off on the equiv ratio until indicated work from both motors were the same.
I found that therm-conv efficiency went up by about 22%, and comb efficiency by about 2.5%. The combustion efficiency was taken from a fit to a data plot, and it’s a little shaky, at best. I recall other plots in Heywood for fuel-conv eff vs equiv ratio, and I should take a look at that. It would be more accurate. Be that as it may, from just a crude estimate here, the model results are suggesting around 25% improvement. Most from just the higher rc.
Because I used less fuel to get the same gross work, peak temps weren’t much different. Peak pressure was significantly higher for the high-rc/short-burn case, however. The heat transfer was definitely higher around peak pressure for the high-rc/short-burn case, but then dropped below that of the lower-rc/long-burn case throughout most of the expansion stroke. Overall, there was less heat transfer through the cylinder walls and out the exhaust for the high-rc/short-burn case.
(The model uses Woschni’s hc for convective heat-xfer and a black-body approximation for radiative heat losses. The later, being fairly small by comparison. Burn is via Wiebe burn fraction. It does not include frictional losses, nor did I include pmep losses.)
So some additional improvement should certainly be possible by eliminating pumping losses from the throttle. Not sure how much that might improve overall mech efficiency, but someone might take a wag at it. I am not confident it would get the overall fuel-conv efficiency up enough to show a 50% improvement. But again…maybe someone has some numbers to throw at that.
I am a bit confused by what the reported gain in fuel-conv efficiency really is. The SAE 7160 article (link given by Tony above) says it doubled. This other article (link below) says a 50% increase. It says,
“That’s where a new system from Transonic Combustion comes in. The California-based startup has developed a fuel-injection system that can improve the efficiency of gasoline engines by 50%.”
Here is the link =>
The other peswiki.com link in Tony's post above suggests 50-75%. It would be good to know what the true baseline is.
Thanks for the other links, Tony.
Eric
