hello to the collective ,
i am constructing a twin engined 1940's type racer . the 2 engines are straight 6 jaguar lumps, aluminium block 4 litre 245 bhp engines . i am tentatively designing them thus ..
gearbox/clutch/flywheel unit(remote).........10" prop........uj mounted to crank end .....engine.........crank snout to 400 lb/ft jurid donut.............crank end......engine.....snout with stock crank pulley harmonic balancer .
so , i have gone from a trq converter on the end of each crank ,to a prop to a flywheel on one ,and a jurid donut on the other .and from a damper on each to a damper on one .
these engines tend to run very smoothly ,and have good balance as stock .
in the past i have converted a c4 auto to clutch ,created 2 gearboxes back to back ,and the fastest turbo minis use my bespoke clutch design .so have a little transmission experience , but not much on harmonics and acrrued vibration re no flywheel.
thoughts?
regards
robert
thoughts?
regards
robert
