udf and expressions
multicaduser
Industrial
Jan 29, 2013
261
I have a template file that contains named expressions and udf's that have the same named expressions.
On my computer when adding the udf to the template file the udf picks up the value of the named expression and applies it to the udf.
On the computer of another user the udf expression changes from the named expression to a standard "P" expression name. The named expression still exists in the template file but is ignored.
Does anyone know what controls this behavior?
NX10.0.0.24 MP1/Windows 7 Service Pack 1
I have seen that you have 10.0.0.24 instead 10.0.3.5.
It's not recommended and check if your colleague have the same version
You can also share your udf. It will be easer to help you
Didier Psaltopoulos
Hi DidierPSICAD
Attached are the template file with the default expressions and the udf along with the cgm. All the files reside on a network drive where they are both created and stored, so access is exactly the same from any computer.
My tag line should have said 10.0.3.5 but it is actually accidentally correct. The system used to be 10.0.3.5 but when IT replaced my computer they installed the wrong version which I didn't notice until now. Our IT department is not well staffed so this doesn't surprise me.
 http://files.engineering.com/getfile.aspx?folder=7ca02ca8-cfc3-4de4-8efb-618e4ff86157&file=nx10_expression_template.prt
Hi MultiCadUser,
You have forgotten to upload the UDf.
Is it possible to dos so?
I might give it a try then.
B.R.
Thanks PDW. Thought everything was uploaded. Zipped everything into one this time. Haven't used udf's since NX2 when I believe it actually created a file ".udf".
I had to jump off of trying to figure this out to get paying work done but will be looking at it more later today.
 http://files.engineering.com/getfile.aspx?folder=8e614817-3ae1-478d-9b53-825e4fc95294&file=expressions.zip
Hi MCU,
I was able to add your UDF to a Library.
It is as you describe.
Only when I change a default Expression, f.e. the locked Expression water_diameter, the UDF changes accordingly.
With the AttributeExpressions this does not happen. So the are not connected...
Currently I am working on a similar topic, and I am in contact with my NX Support.
If they come up with a solution, or a workaround, I will share this offcourse.
Br.
Pascal
Update on this issue. When I noticed I was not on 10.0.3.5 but was on 10.0.0.2.4 with the new computer I had IT load my system with 10.0.3.5. Low and behold the exact same files stopped working, which they had been for a couple months with the new computer.
The other system also had 10.0.3.5 so I'm assuming this is a regression.
I contacted GTAC and the incident report is IR8000695.
I'll post when something happens with this issue. Right now I'm pushing for NX11 to try.
Well this has been upgraded to PR 8000695 and has been tested by GTAC up to NX12 with the same results of not updating.
