UG-45 Min Nozzle Thickness
BrentP
Materials
Apr 12, 2013
8
Question for folks.
Is there any time that a 1.5" nozzle, not an inspection opening, is exempt from the minimum thickness of UG-16, 0.0625" ?
No,
Assuming 0.625" is min required for tb1 and/or tb2
tb = min (.127", max(.0625",.0625")
tb = .0625"
tug-45 = max(ta,.0625")
So even in ta is less than .0625", max is 1/16".
Thanks.
That's what I thought. New to all this so had to double check.
Thanks again
Don't forget to apply any corrosion allowance.
Mike
There is a misconception among some Certificate Holders that small nozzles and fittings are exempt from UG-45 (or UG-44) calculations. Small openings that comply with the requirements of UG-36(c)(3)(a) are only exempt from reinforcement calculations and UW-15 weld strength calculations.
All nozzles are required to have UG-45 nozzle neck calculations and B16.9 and B16.11 fittings are required to be calculated as straight seamless pipe per UG-44.
Bob
