RLD89
Aerospace
- Aug 24, 2015
- 21
Please advise.
The attachment shows three callouts of a surface profile.
The top picture is simple enough. A bi-lateral tolerance with the limited length is called out with a center line (one small lines between longer lines, reference Figure 1.1 of 1994).
The middle picture depicts a Unilateral tolerance over a limited length. The unilateral tolerance over a limited length is called out with a phantom line (two smaller lines between 2 longer lines, reference Figure 6-18 of 1994). Technically, without the “single dash” the length is not called out correctly.
The bottom picture alternative to the Limited length unilateral tolerance. It uses both types of lines on opposite sides of the surface to be control. This is the only way to represent both types of lines and meet the requirements of the 1994 spec.
Perhaps either the mid or lower options will achieve the desired result. To make the drawing as clear as possible I will choose lower picture and show on a blown up detail view to make the intent clear. A flag note could be added to clarify? Any suggestions for improvement?
Thanks,
Thanks,
