Application: Drafting
NX11 / TC11
Is it possible to show different callouts of the same parts which are packed in a partslist?
For example: there are 3 electrical identical parts in an assembly. Only the code is different (callout or ItemID). You can change the itemID / callout per Item. In the partslist they get automatically packed and the callout is showing: [...]
So on the drawing the callout for all three parts is also showing: [...] and not the value which was entered.
tia
with kind regards Boris
NX11 / TC11
tia
