US units to SI units 2
espus81
Hello, probably stupid but cant find a reliable answer on Google.
I`m reading McCormac`s
on shear walls and i`m wondering how to translate the applied force in the calculation example on the shear wall to Newtons. Please see attached picture.
I thought the meter was originally defined as 1/10000th the distance from Paris to the North Pole. Of course there is a master meter (reference standard) in Paris.
Both those were long ago deprecated in favor of the current definition.
The current definitions of all SI base units require no physical artifacts, which degrade through handling and measurement, and can be tested and replicated in any sufficiently equipped laboratory in the world. The lone holdout was the kilogram, which was not converted from artifact-based standard to a pure measurement until last year.
TTFN (ta ta for now)
The article on the "metre" in wikipedia has an interesting discussion of the history of standards, and the increased precision of the standard as time went on, see the table under the "Timeline" heading:
1795 - defined as one ten millionth of distance from pole to equator - relative uncertainty ~ 10-4
1799 - platinum bar - rel. uncertainty ~ 10-5
1889 - Pt/Ir bar - rel. uncertainty ~ 10-7
1960 - 1650763.73 wavelengths of light from a specified transition in krypton-86 - rel. uncertainty ~ 4x10-9
1983 - Length of the path travelled by light in a vacuum in 1/299,792.458 second - rel. uncertainty ~ 10-10
One could argue that past 1799 most of us would probably not care too much, unless dealing with fairly high precision machinery or electronic devices. Then again, this computer I'm typing on, and my phone, and other electronics, would probably not be possible without the dimensional precision implied by at least the 1960 standard. What the list really says is that the increasing ability to measure time to very high precision/repeatability means that you can improve other measurements by tying them to a time-based standard, so why not?
Wasn't the original intent that 1 gram = mass of 1cc of water? If that were the case, gram was originally the base unit (hence the "historical reasons" in robyengIT's previous post).
I'd've thought we could define a kg as the mass that exerts a (tension) force of 1N when in a centrifuge with a radial acceleration of 1m/sec^2 at geo-stationary orbit (weightless?).
Note that the newton is not a basic unit, and includes kg, so it's a circular definition.
The kilogram's issue is that not so much a "why not?" it was that the "standard" keeps changing every time it's been measured, so no one is even sure whether the standard is still valid.
In fact, the biggest hangup with the kilogram's new definition had been that the physical constants contemplated weren't immutable either, hence the new definition requires that h be defined explicitly as 6.62607015*10^-34 * m^2 / s
Cal91 (and some others).
For a good explanation of "base units" see
They are applied to the seven base "physical quantities" in terms of which all other physical quantities can be defined.
We could measure any or all of these base physical quantities in any arbitrarily chosen units.[ ] Furlongs for length, carats for mass, etc.[ ] Our physical laws could still be expressed mathematically, but would require the inclusion of arbitrary constants.[ ] By choosing our "base units" cleverly we can arrange things so that many of these arbitrary constants are unity.[ ] This is what a good "system of units" will attempt to achieve.
For an example, consider Newton's Second Law.[ ] As originally formulated by Sir Isaac, this stated that "the rate of change of momentum of a body is directly proportional to the force applied", which (for constant mass) readily converts to F[ ]=[ ]k.m.a where k is a constant of proportionality.[ ] Choose your base units cannily and this "simplifies" to the now familiar F=ma.
