I received a 250 HP motor with some "noise" problem. On examination, I found that the noise was coming from the 8 groove, V belt pulley of the motor.
The motor shaft dia is 109.92 mm and the pulley bore is 110.20 mm i.e. 0.28 mm loose fit. The key was also loose both in the shaft and the pulley.
The motor runs smoothly without the coupling.
I would appreciate if any one can point out the kind of fit of V belt pulleys (loose fit, mallet fit or interference fit) require.
Any pointers to web references would be nice.
(I did google v belt pulleys but got 43,800 hits and the few sites I saw did not have this fit information).
