Valve springs too strong? 1
HoofHarted
16
I have a 16V cylinder head that I'm trying to fit Merc valves to. The Merc Valve Springs are slightly longer, smaller in diameter and are much stiffer, than the orginal springs. I would like to know if it possible to use these springs with the hydraulic bucket lifters and not break the camshafts from excess force.
Hammer and socket is good for disassemble, but somewhat problematic for assembly. A valve spring compressor for a typical modern four valve costs over A$500.00. At that price I had a specialist head shop remove and reinstall the valves on my last cylinder head overhaul of my Honda.
Pat
See FAQ731-376 for tips on use of eng-tips by professional engineers &
for site rules
Yes, very tricky to reassemble everything with a socket and hammer. It would be useful to know if there is a "fits-everything" compressor available at a reasonable price (like around $50) in Oz.
No. There is not otherwise I would own it. According to my wife, I already have more tools than Bunnings.
Pat
for site rules
BigVlad, buy the proper tool (check eBay), use it, then sell it for 50% of cost if the price is a problem. There is no substitute for the right tool.
Not to be too much of a smart ass, but----It really is not all that difficult to simply make the adapters necessary to use simple valve spring compressors to service OHC and DOHC cylinder heads. I have made several for myself and for others in the past. I have one I use on our DOHC Lotus twincam that I made up using a piece of 1 1/4" tubing and a hacksaw...took about ten minutes....works like a charm. It is always handy to keep a small mechanics magnet to retrieve the splitlocks you seem to drop occasionally, though! ;o)
Rod
There are several "rules of thumb" for the proper valve spring pressure on different types of camshaft configurations and types. Setting up a cylinder head with the "correct" valve spring pressure is a relatively simple and cheap method of increasing engine performance. One thing for sure is that you have to check the seat pressure and open pressure as both are critical. It is possible to have the right amount of spring pressure when the valve is on the seat and too much when the valve is open and vice versa. The only way you can determine whether or not the springs you have will work is to properly measure the "installed height" of the valve spring when the valve is closed and check the springs with the retainer installed on a valve spring tester. This is the distance between the bottom of the valve retainer and the spring pad. The easiest and less expensive way to measure this is with a snap gauge and a set of calipers or micrometer. One you have this measurement you can properly set the installed height and determine if the open pressure is enough or too much. As for breaking the camshaft, this is a very rare occurance if you do it correctly.
For disassembling the valve springs on a cylinder head, the proper way is with a spring compressor but there is an acceptable alternative to this. They make a tool that is magnetized that is specifically for keeping the valve locks from "flying everywhere". This tool is relatively inexpensive and is made by KD tools I think. With this tool, you use a hammer and when the spring is displaced enough, the locks "fly" up into the magnetized hole that holds them in place. This tool also comes with another piece to allow for re-assembly.
