slickstyles5
Aerospace
I am looking into installing a VFD (variable freq. drive) on an existing rotary pump (PD pump). This pump supplies several engines with fuel (3 branches). I want to figure a way to adjust the RPM of pump motor to vary the flow out of the pump all depending on what the engine really needs. Can I do this by monitoring the pressure I need at the engine? That way, as soon as the engine needs more fuel and the pressure starts dropping, the VFD would react and increase the pump speed, therefore increase the flow?
What do you think?
Any ideas?
Thanks!
What do you think?
Any ideas?
Thanks!
