VW DCC semi-active dampers
JasonCSBB
10
HI all,
VW has their new DCC "dynamic chassis control" system that uses semi-active dampers.
Anyone know their system bandwidth? Similar to GM's recent magne-ride incarnations?
This vid suggests bandwidth is similar - enough for low-frequency bumps but not high frequency ones:
More on it:
Hi Jason,
Please remember, that such a system is not "active", it doesn't supply energy to the suspension.
It's a form of an "adaptive" damper control, which can vary the energy disipation in the suspension, according to some parameters.
AFAIK the VW system comes from Monroe [Tenneco], produced in Spain and uses Öhlins (CES) valve technology.
If you are interested in some of the in and outs, you may want to have a look at this thesis paper.
in more direct response to your question, step response time for the valve is between 5-25 ms [40 hz], but at higher frequencies, other factors, such as damper (body) stiffness and oil characteristics feature quite strongly as well. But up to 20Hz shouldn't be "a problem".
to see the difference between a "fully active" and a "adaptive" (sometimes called semi-active) system, you may want to take a look at the following presentation, which compares Tenneco's "active" (ACOCAR) and their "adaptive" (DDC, CES etc.) systems, under different conditions.
