Warning/error table
matos11
13
Hello.
Could anyone help me with my problem? What should I do when workbench lists always this warnings/errors.
Thank you.
Hello matos11,
It looks like your solution failed to converge because your constraints were inadequate and/or conflicting. You should recheck your constraints and investigate the partial results from your analysis to see if you can determine exactly what went wrong. Alternatively, if you provide a more detailed description of your analysis you may get more focused advice here on the forums.
Good luck,
Dave
Ok, so.
I need to investigate the stress- and deformation analysis of pliers.
I have pliers (see pic.). I set this boundary conditions:
1. forces on handles
2. forces on cutting edges
3. joints (reference-mobile): revolute - DOF only around z-axis
3.1. revolute: right handle-left handle with centre of rotation in the centre of the
pin
3.2. revolute: pin-upper cutting edge with centre of rotation in the centre of the
pin
3.3. revolute: left handle-pin with centre of rotation in the centre of the
pin
3.4. revolute: right handle-pin with centre of rotation in the centre of the
pin
3.5. revolute: pin-lower cutting edge with centre of rotation in the centre of the
pin
4. contacts (all bonded):
4.1. between handles
4.2. between handles and cutting edges
4.3. between handles and pin
forces applied to the handles are 400N, forces acting on the cutting edges 1200N...principle of lever.
I set iterative solver and large deflection.
I dont know what I did bad.
Please, help :)
Martin
 https://drive.google.com/file/d/0B0OilJPwBKJ8TnJSR0dEbmMyNDA/edit?usp=sharing
