UGMENTALCASE
Aerospace
- Oct 10, 2011
- 123
Hi all,
We are currently working to standards laid out by our customer, and we have to use an environment, which has been set up, which includes seed files, drawing borders etc etc.
My question is, we are not allowed to use WAVE Linker, once upon a time we had an assembly you make the part workable and then link in using WAVE linker a surface/curve or whatever it was. However since we are not allowed to use it, is there a way around bringin in surfaces from one part to another. Nothing is on the same axis so that doesn't help. The set up we work in seems to block anything to do with the WAVE linker. Even if i save my parts in this environment, and then open the part in a standard NX 6 session, i still can't use WAVE linker, it seems to completely block any use of it, even after a file save.
Any help would be great!
