eng003
- Jan 4, 2012
- 67
so it is said wet curing maintains the moisture in your concrete slab for the hydration process and will help your concrete gain a higher and predictable strength. I have three questions regarding this:
1. Doesn't increasing your water to cement ratio decrease your strength? or does the water not get into the mix after placed?
2. What is the most common practice for residential slabs wet-cure or not?
3. I placed some concrete not intending to wet cure and then accidentally splashed some water in the middle which eventually spalled up, so why would more water be a good thing?
