What is this device??
Ray2
Military
Nov 13, 2004
15
Can anyone identify what this device is for on the end of this hydraulic cylinder?
Thanks in advance
Ray D
Which one?
image.php
The rectangle metal block and the 6 sided device screwed in by the port. This is on the rod side.
Strictly a guess, but, probably some sort of pressure control like a Counterblance Valve to retard a vertical rod down cylinder with a load that would try to make it drop when a directonal control was shifted to extend the cylinder.
Some of these Pressure Control valves had an adjustin screw in the end or had the adjustment covered by a Hex Cap.
Bud Trinkel, Fluid Power Consultant
HYDRA-PNEU CONSULTING
Looks like it has epoxy on it to prevent adjustment of the setscrew in the end of the body.
An adjustable control of some sort. Maybe a flow control.
Ted
Scrape the paint off the hex faces. The manufacturer's name and part number may be embossed there.
Ted
I hate when that happens, as soon as you give up and ask a question, you solve it. The cylinder is part of slide mechanism for an RV with a synchronizing cylinder. In case one of the slide cylinders binds and causes a pressure increase, this device locks the cylinder so damage to the RV can not occur.
Thanks for the help,
Ray D
