BendingMoment123
- Apr 1, 2020
- 25
Hi, I just want to verify my stress results in my plate segments in Strand7 using Roark's formula. Should I use the surface (either -Z or +Z in terms of the plate's local axes. In this case the top of the plate is the -Z surface), or mid surface calculated stresses. So you would have either a mid surface stress in the global xx,yy and zz directions, and you would have -Z surface stress calculated in the global xx, yy and zz directions.
Note that the dark green plates are stiffeners welded to the surface of the light green plate. I just want to check a portion of the light green plate, which I have highlighted in red below. The highlighted portion has a uniform pressure applied over it of 7300 kPa. The plate dimensions are 2" X 2" (50.8 mm X 50.8 mm) and is 17.5 mm thick. What edge support configuration would you assume as well?
