tehribo
- Nov 30, 2011
- 12
Hello!
The first formula which I read in EASA's "AC Motor redesign" book seems very strange to me. You can check it the attached file or:
CM2 = CM1 X (T1/T2),
My question is, ok if I change the lenght (turns) and the area of the wire. I am changing also the resistance of the winding, correct?
So I am changing the parameters of the whole motor?
So is this formula true?
Thank you!
P.S in the formula :
CM2 = circular mil area per turn of the new winding
CM1 = circular mil area per turn of the original winding
T1 = turns per coil of the original winding
T2 = turns per coil of the new winding
- Electric motors Bulgaria
Thank you!
