matalik
- Feb 15, 2007
- 5
I have a tapped hole on the end of a precision shaft. The hole is on the center line. What is the best way to apply a postion tolerance so that the threaded hole stays on the centerline? THe shop that makes the part seems to have a hard time with keeping the tap straight and I want to make sure that the drawing is providing enough information to them. thanks.
