Concrete column or concrete wall based on length
Rgray26
1
Hi everyone!
I am currently dealing with a project where a concrete wall section is quite small in regards to its length. I was wondering if CSA A23.3-14 has length requirements that classifies whether a "small" wall section should be analyzed as a column.
I seem to recall that if the length is 1/3 the height, it is a wall... but not sure... and I don't have my code handy...
Over here its a wall, not a column, if its length exceeds 4 times its width.
could be 4x... don't use conc code often...
from the Canadian code (CSA A23.3)...
