Centrifugal Pump Suction-Inlet Design & Best Practices
jcth
3
Greetings; I install (typically) temporary water remediation systems.
Scenario:
12 qty - 21k temporary holding tanks (Baker Tanks; Frac Tanks, etc…);
6” mid-low tank outlet ports feed (via hose or pvc pipe) a common 6” pvc manifold about 80’ long in front of tanks providing pump inlet suction supply.
Two or three centrifugal pumps with flooded suction from tank inlet supply manifold, discharge/pump down tanks at 1800 gpm total output required. Pumping Medium is water at ambient temp (50F).
Best practices: 5-10 pipe i.d. straight inlet run to pump suctions; 1-2 suction Dia sizes larger than pump suction Dia; suction velocity no higher than 8 ft/sec.
Question a) do I consider overall velocity in the 6” tank manifold inlet supply? Or just in the straight run suction inlet to pump?
If I just consider individual pump suction velocities splitting flows then:
b) two pumps at 900 gpm each is over 10 ft/sec suction velocity and problematic?
c) three pumps at 600 gpm each is under 7 ft/sec suction velocity and better?
Why - justifying increased costs of suction plumbing sizes SOP’s, freeing up pump fleet over utilization, and reducing pump wear and tear…
Thank you for feedback and guidance.
You should check velocities at all points.
10 fps isn't all that bad as long as it leaves you with enough pressure (NPSHR) at the pump and the pipes don't shake on start or stop, or a quick valve closing.
Avoid velocities over 15 fps everywhere.
7 fps in long pipelines gives better pumping costs. If its not a long pipeline, generally no problems.
If its a suction line, then (again) as long as NPSHR is OK its fine. Low velocities are better; minimum probably 3 fps.
If you do not know the NPSHR of the pump, then you should always have at least 6 psig at a water pump suction inlet.
Your Sizes are typically OK.
Avoid ells near suction inlets.
Header diameters 1 to 2 Sizes larger than the largest branch diameter. Use 2 for larger diameter piping. 1 for smaller diameter piping.
3 pumps are usually 2x more difficult to use than 2. Generally the less, the better.
What did this look like in terms of layout?
If you avoid getting 1800gpm at any point in your 6" pipe would be good. That's a very high velocity (22ft/ sec).
Is this manifold being fed by me than one tank? How many?
10 fps is a bit high but at those lengths you won't be hurting for NPSH so it should be OK. Go for two pumps if you don't mind losing one for a while if it stops.
Thank you very much.
If this was a permanent facility/plant install and pumps running steady state, then it would be engineered 100% and focused on pump efficiency; however we run remediation systems intermittently depending on type of project, whether we're treating with coagulants/flocculants for suspended solids on construction sites, which requires a larger number of tanks to keep tank velocities down for proper settling prior to sand filtration...
I attached a photo for reference... yes we set up tanks side by side parallel to each other; inject coagulant/flocculant into "Pretreat Train" filling into rear of tanks; solids settle out before conveyance out of tank front into manifold and onto sand filters.
How many tanks depends on overall flow rate, and what the contaminants of concern are. Suspended solids (construction, clay soils, sediment, etc...) it's good to target about 150 gpm per tank.... so 1,800 gpm/150 gpm = 12 tanks... Other projects like ground water remediation, where water typically runs clean in terms of solids but treating with GAC for dissolved metals, VOC's, etc... we can run a higher flow rate/velocity through tanks and have fewer, but still may be other limiting factors.
Yes three pumps is ridiculous and I'm trying to educate my team. Two is perfect as this provides what I call internal redundancy in case one goes down.
Thank you thank you!
 https://files.engineering.com/getfile.aspx?folder=658b902d-9e6f-4c2b-94b4-626ee9474429&file=OAuKe6Ei.jpeg
Where have you taken those from?
for info
If flow rate is nearly steady then 2 pumps will be better.
If flow rate can be lower for some time then investigate whether 3 pumps will be better for handling lower flows such that one or 2 pumps can be switched off.
The velocity limitations are mostly to prevent excessive erosion for continuously running systems as well as to limit the required pump power and NPSHA. For non-continuous systems there can be certain relaxations of these criteria if this can be justified from cost point of view.
Now! Or it may be too late.
You may want to take a look at the document attached
Pierre
  • Suction piping design.pdf
