A four cylinder INLINE engine designed in the last 30-40 years or so will not benefit from a torsional crank dampner. Reason is the crank will be built quite robustly (very little harmful rotational harmonics).
However, this same engine will exibit violent vibration modes, NOT due to crank harmonics, but imbalance in other areas (planes) such as horizontal plane imbalances.
Mitsubishi fixed this with their "balance shaft" system. This is composed of two counter weighted shafts rotating in the crank main bearing plane.
Cheaply built engines (spildly crankshafts) can benefit, or need a dampner. The Ford "Model A" is an example. An extremely cheaply built engine with a very weak crankshaft. Put almost ANY viscous dampner on the crank and main bearing life will be extended by thousands of miles.
