Hi all,
CL 8.2.8.2, under equation 8.2.8.2(1), it states that the total tension force "need not be more than that required at the section with the maximum tension force demand for flexure, axial, and torsion"
Does this mean to say, that if there is no torsion or axial force, then a cross section can be design for the tension force due to flexure only, T=M/z? And the additional tension force from shear does not need to be accommodated?
From my checks, the additional tension forces due to shear can add substantial tension reinforcement, that never would have been required from the 2009 code.
