Boeing 737 Max8 Aircraft Crashes and Investigations [Part 7] 16
Sparweb
Aerospace
May 21, 2003
5,167
This post is the continuation from this series of previous threads:
thread815-445840
thread815-450258
thread815-452000
thread815-454283
thread815-457125
thread815-461989
This topic is broken into multiple threads due to the length to be scrolled, and images to load, creating long load times for some users and devices.
If you are NEW to this discussion, please read the above threads prior to posting, to avoid rehashing old discussions.
Thank you everyone for your interest! I have learned a lot from the discussion, too.
Some key references:
Ethiopian CAA preliminary report (Link is now broken. See PDF download below, 3 MB)
Indonesian National Transportation Safety Committee preliminary report
A Boeing 737 Technical Site
Washington Post: When Will Boeing 737 Max Fly Again and More Questions
BBC: Boeing to temporarily halt 737 Max production in January
www.sparweb.ca
 https://files.engineering.com/getfile.aspx?folder=7858b23f-a660-42fb-864f-782f40e01dc0&file=Preliminary_Report_B737-800MAX_,(ET-AVJ).pdf
New and read new posts only work if there have been new posts posted. If I want to simply add another post to a slow thread, its scrooling time again.
It was a Heathkit H89 - assembled myself, with all the goodies list.
Cost appx $3000 in 1981, which was about the same as my new Jeep J-10 pickup.
“What I told you was true ... from a certain point of view.” - Obi-Wan Kenobi, "Return of the Jedi"
the other issue is when you looking at it on a device you only want to view on and not login.
Its easy when your in front of a sit down computer dealing with it. Mobile devices its somewhat of a challenge depending what the layout its decided to use.
But there is a "Reply To This Thread" button that takes you straight to the end of the thread.
That only works works whe your logged in. Personally on company IT gear I never log in with personal accounts.
Ipad its not so bad on but phones its a whole load of finger flicking.
ax1e said:
...its scrolling time again.
Sure. I can split the thread.
Bear in mind that some of you guys are talking about Osborne portable computers this week so what's really adding to the post count, eh?
Thank you everyone for this enjoyable discussion so far!
This topic is being broken into multiple threads due to the length to be scrolled and many images to load, creating long load times for some users and devices.
Please continue the discussion at the new thread: thread815-473001
