I used this one recently but it did not behave as expected. I "bonded" a nut and washer to a bolt which was constrained to a hole in another component. When I changed arrangements the bolt moved with the part to which it was constrained but the nut and washer stayed in original position. The bond constraint is "shared" on both arrangements so it seems set up properly. Any ideas on why this is not working properly?
