Can you increase P in water via air pressure? 18
Mechbob1
21
Please help settle a discussion…
As per the picture, can you increase the pressure in the water by increasing the pressure in the air above? It’s a sealed container.
If yes/no, why?
I thought you couldn’t, due to P equaling rho x g x h. But someone else reckons you can, and I’m second guessing myself.
Thanks.
 https://files.engineering.com/getfile.aspx?folder=8ae3383b-f3bd-41aa-8d6f-02b0bdae4d1a&file=image.jpg
0.1 bar. silicone, or hot glue should work just fine.
Oh. You're joking.
Good one.
A black swan to a turkey is a white swan to the butcher ... and to Boeing.
Actually on my DIY projects, I can never get enough tape on those things the first time.
At some risk of being cut down in flames:
Divers all know that as they go lower the pressure inside the water increases. Same thing if compressed air is added to the top of the container. Water being nearly incompressible only means that the volume it occupies does not change much.
turn on the flame throwers!
