Dear All,
Power cables installed beside each other, can not tolerate as much current as a single piece of cable.
It is due to thermal effect of each cable on the others.
IEC 60364 and IEC 60502 have specified correction factors for such arrangements.
I am going to put two layers of cables inside underground trench.
Trench will be filled by fine sand. Vertical distance between layers will be 20 cm. Each layer includes 9 cables.
IEC guides me about grouping correction factor for 9 cables in a single layer. But it has nothing about TWO UNDERGROUND LAYERS.
Would you please let me know the correct method? Certainly many people have seen such problem, when sizing their cables.
