utomop
Geotechnical
- Sep 16, 2006
- 4
Hi all,
At the moment I have a problem in modelling the plane strain model of a square material (cement mortar) with a pre-existing crack in the middle which form an angle of 45 degree. This plane strain model is subjected to the compression load at the upper part and the lower edge has pinned constraint. When I submitted the job to analyze, the job can be done but I could not see the propagation of this slant crack in the deformed mesh, even though I increase the load which was considered exceed the allowable stress of the material. Anayone has experience with this kind of problem?
Thanks in advance
Utomop
Thanks in advance
Utomop
