Create block line for each body NX drating
Little_fox
3
Does anyone know how can I create view in drafting NX that each body will be a block line and pile up?
Not sure what you are trying to achieve. Can you provide a picture with what you have in mind?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Ah. It's like how can I create block of some lines like Autocad, so I can choose them faster.
Can you show a picture of what you want made into a block line ?
Jerry J.
UGV5-NX1884
Looks like you want to put a number of lines in one group.
You can use "Menu - Format - Group - New Group" to create one and add objects to that group.
If you then set the Selection Filter to group, you can select the objects by group.
NX9 / TC10.1.2
