Hi I do a design for deep beam by finite element method. the modeling is area section ( membrane type ) with local axis
1 in the horizontal direction and local axes 2 in the vertical direction. the section cut out put forces and moments are reported in the directions 1 ,2 and Z.
please advise what is the relation between axis on the cutt section report and the local axes of the area element.
is direction Z is the global ? if so
how we can apply the results in Z direction in case of inclined members. please refer to attachments.
