Dimension to CL - not to center
ewh
Aerospace
Mar 28, 2003
6,147
NX5.0.2.2
In earlier versions, when dimensioning to a centerline, the extension line would do just that - only dimension to the line and not the center.
Now, when I try to dimension to a centerline, the extension line always snaps to the actual arc center. This is a problem especially when dimensioning in a detail view. The center point is usually FAR from the feature I am trying to dimension, and I end up with an extension line crossing the drawing to apparently nothing (the actual center point).
Is there any setting to fix this, or will I have to submit an ER? I don't see this as an enhancement so much as something taken away.
Clear as mud?
Believe it if you need it or leave it if you dare. - [small]Robert Hunter[/small]
EWH,
Make sure the status is showing "Existing Point - Linear Centerline"
Specialty Engineered Automation (SEA)
a UGS Foundation Partner
It does, but still dimensions to the center point ...
Great John!
Is 5.0.3.2 available yet?
Thanks!
I just loaded 5.0.2.2 and was disappointed to find this problem.
Our IT guy is often a great help, but doesn't keep NX up to date unless a disk is mailed to him, so I've had to take over the task.
Gotcha... I'm now on the notification list, so I'll find it easier to keep up to date.
