ewh
Aerospace
- Mar 28, 2003
- 6,147
NX5.0.2.2
In earlier versions, when dimensioning to a centerline, the extension line would do just that - only dimension to the line and not the center.
Now, when I try to dimension to a centerline, the extension line always snaps to the actual arc center. This is a problem especially when dimensioning in a detail view. The center point is usually FAR from the feature I am trying to dimension, and I end up with an extension line crossing the drawing to apparently nothing (the actual center point).
Is there any setting to fix this, or will I have to submit an ER? I don't see this as an enhancement so much as something taken away.
Clear as mud?
Believe it if you need it or leave it if you dare. - [small]Robert Hunter[/small]
Clear as mud?
