In CREO 4.0 if you are creating a model and you locate a hole from one edge of a part and then later use the Geometric Dimensioning tool and locate the same hole with a basic dimension from a different edge of the part, which dimension will appear on the drawing if you use the "Use Model Dimensions" option?
