Dynamic pin shear force 2
LeonhardEuler
200
How do I calculate the strength of a pin that will have a dynamic force on it from an object falling at several feet. Is using the simple formula of f=mv^2 adequate, or do I need to consider kinetic energy and impulse? Thanks
One additional thing you might consider is some sort localized deformation (i.e. contact stress). If you get a little, you might be able to justify less stiffness than you are using.
If not that, I'd look at your whole system (as suggested before) and ask yourself if a stiffness that high is really possible.
I don't think there will be much deflection in the rest of the system except right at the pin hole. The pin is through vertical HSS tubes
By the way LE.....what is this thing? You mentioned 200 lbs falling something like 6 feet. This isn't fall protection is it? (The anchorage limit there (as per OSHA) is about 5000 lbs: people are too squishy to deliver much force.)
Warose its not fall protection. It's proprietary info, but it is basically a steel object falling. Star for "people are too squishy" cause it made me laugh.
