structural-eng
I'm looking for recommendation regarding structural finite element analysis software for designing simple steel structures for an electrical substation. We have a client (an electrical engineer) that we have been designing substation structures and foundations for that is looking to bid on a new project and the spec for the project requires "Structural Finite Element Method (FEM) analysis should be used as a base method for design. Hand calculations of components may be used only under written approval." Our company has been around for 40+ years and we have never gotten into finite element design. The work that we do is not complicated enough to warrant it. These substations are very basic structures (cantilevered columns, pinned and simple fixed end connections, etc) and the member sizes used are driven by desired geometry and deflection limits and rarely by strength requirements. The only area where we believe we could likely reduce the structure size from our current designs is the base plates which have large holes for galvanizing and are on leveling nuts which requires very thick plates when using a traditional design approach. Any recommendations would be appreciated.
