Flexible Diaphragms
erenattos
3
hi folks, i´d llike to know how can i modelate a flexible floor concrete diaphragm in ETABS
AS far as I know, you just need to create a shell property in "Define" "Wall/Slab/ sections"
The shell element should have the appropiate material properties and thickness
hope this can help
In a change from previous versions, from V7 ahead, flexible diaphragms are the default in ETABS. If you desire a rigid diaphragm you have to define it explicitly. So, essentially, if you do nothing you will end up with a "flexible" floor diaphragm.
Amadeus
