Oct 29, 2004 #1 erenattos Structural Oct 29, 2004 3 PE hi folks, i´d llike to know how can i modelate a flexible floor concrete diaphragm in ETABS
Oct 30, 2004 #2 ctcing Structural Jun 27, 2004 4 MX AS far as I know, you just need to create a shell property in "Define" "Wall/Slab/ sections" The shell element should have the appropiate material properties and thickness hope this can help Upvote 0 Downvote
Nov 3, 2004 #3 amadeus Structural Mar 5, 2003 49 DO In a change from previous versions, from V7 ahead, flexible diaphragms are the default in ETABS. If you desire a rigid diaphragm you have to define it explicitly. So, essentially, if you do nothing you will end up with a "flexible" floor diaphragm. Amadeus Upvote 0 Downvote
