Galvanic Corrosion in valves and pipelines
justPIFit
Industrial
Jun 11, 2013
4
Has anyone ever come across a solution to Galvanic corrosion before? It occurs a lot on oil platforms because of contact with seawater. I read this article about a solution to galvanic corrosion in valves and pipelines could be to replace graphite with a material called HNBR?? Apparently this is one of the only solutions to Galvanic Corrosion in Valves and pipelines in the market place today.
Any thoughts welcome please.
same here
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
