half pipe jacket on a cone
Aloni
32
hi to all,
I need to design a conical pressure vessel with half pipe jacket.
The conical vessel is with full vacuum and the half pipe jacket is with 3 barg.
Is there any code regarding this issue?
According to AD-2000 B6 (Cylindrical shells subjected to external pressure) the code referring to cylindrical shell geometry,
What is the case to a conical geometry ?
regards
aloni
Aloni, how about B2?
Mike
hi mike,
B2 (Conical shells subjected to internal and external pressure)
what about the half pipe jacket., can it possible to use the half pipe jacket calculation from B6 on a cone?
regards
Aloni
See in B2 "equivalent cylinder diameter" and "equivalent cylindrical length"
r6155
Aloni, not familiar with those Codes, have no idea.
Thank you all.
Regarding the equivalent cylindrical length.
The number of winding (half pipe jacket) on the cone is different from the number of winding on the equivalent cylindrical length.
For example: the number of winding on the cone is 8
And the number of winding on the equivalent cylindrical length is 15
Due to the fact that they act as a stiffener there is not enough space to put them all on the cone.
Aloni
Can you tell us more information, some drawing?
r6155
Calculate the equivalent cylinder diameter and equivalent length, then calculate the required thickness of this cylinder with P= full vacuum with the same quantity of half-pipe as your drawing.
Also you can see ASME VIII Div.1
r6155
Hi r6155
Thans for your tips
Aloni
